Hi @karen33133
Try the following and check if the screen backlights turn on and stay on without flickering. There will be no images on the screen when doing this test as the mainboard has been disconnected..
Turn off the TV if it is powered on, disconnect the power to the TV and then remove the back cover from the TV.
Disconnect the cable between the mainboard and the power board, at the power board end only.
Reconnect the power to the TV and check if the TV screen backlights turn on and stay on.
If they do then most likely it is a mainboard problem.
If the don't or if they flicker it is either a backlight problem or a power board problem.
Be safety aware when doing the above as there is exposed, lethal AC voltage on the power board. Disconnect the power from the TV before doing any further work in the back of the TV.
crwdns2934113:0crwdne2934113:0
crwdns2915270:0crwdne2915270:0
crwdns2889612:0crwdne2889612:0
@karen33133 explain this "the screen is completely black (no faint images) and it flickers globally " a bit more. Your power LED does not come at all? The screen is black so what flickers? One you have the back cover off and checked for the backlight as @jayeff already suggested, take a couple of well -focused pictures of those boards and post those with your Question. That way we can see what you see. Adding images to an existing question
crwdns2934271:0crwdnd2934271:0 oldturkey03 crwdne2934271:0
Basically there is no red power light coming on. There is a global flicker from the top left to the top right sides of the screen and no faint images when a flashlight shone on it. I’m thinking it’s likely a power supply or capacitor issue, it’s just working out if that’s doable with DIY.
Also, no sound but that is mainly because I am unable to select anything to test it due to the black screen.
Will try to get images.
crwdns2934271:0crwdnd2934271:0 Karen crwdne2934271:0
