Nintendo's first 3DS handheld device released February 2011, identified by model number CTR-001.
Stripped screw at the backpanel
Because my own foolishness the last screw in the backpanel of my old3DS is almost completely stripped
How can I remove it now? I don't have a drill and even if I do I don't think I can apply a drill here.
Hi Fox!
Here you can find some tips and tricks: https://www.bhg.com/home-improvement/adv...
I know that @oldturkey03 know more about this. Maybe Oldturkey03 can tell you his personal opinion what works best!
When this happens to me, I used to drill it out. This is the most effective way for me. But let's see if Oldturkey03 know more about this!
Agreed, Oldturkey is figuratively the patron saint of this forum. Everything would fall apart without him lol
@shingle @dan0 you guys are too funny. It's great working with you all :-)
@foxmccloud there are really not to many options. I don't think that any rubber band or super glue will work for you. Neither one of those things could take the torque needed to remove the screw. What you do want to try is a NEW screwdriver and you can even try a size bigger. It just has to be new. Then push inward while you try to turn the screw loose. If that should not work, you will have to invest in a drill.
Actually, I would get a rotary tool since you can manage that better in this type of environment. There is plenty of room to drill this screw. Remember, you really do not drill the screw out. you just drill enough to separate the head of the screw from the threaded part. If you use a drill bit that is more that 1/2 the diameter of the screw head it will do the trick. You will remove the rest of this screw with a pair of pliers after the back panel comes off.
If you have a any kind of garage or maintenance shop in your area, take it there and ask for some help. I can't imagine that anybody would even charge you for drilling it out. It's a 2 minute job with the right tool
Thanks! It sounds like I have to find a professional as I don’t have a drill and don’t trust myself on drilling at such a tight space😂.
Fox McCloud crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 103
