I used windows 10. Then it was showing plugged in (not charging) now i was installed windows 11. Now its not showing (not charging) but it was stucked at 1%. I was using my laptop with only ac adapter
If a device is plugged in but not charging, there are several possible reasons, including:
Your charging cable could be loose, unplugged, or damaged.
Your charging cable could have a weak connection because it wasn't made by your laptop's manufacturer.
Your charging ports could be clogged with dirt or debris that is keeping it from powering up properly.
Here are some things to try:
Check the connection: Unplug the charger from the device and the wall outlet, inspect the connection points for damage or debris, and reconnect the charger.
Check the outlet: Plug another device into the outlet to confirm it's working.
Try a different cable or charger: If possible, try using a different USB cable or charger.
