The Xiaomi Poco X3 Pro is an entry level smartphone by Xiaomi released March 2021. It is equipped with a 6.67" IPS LCD screen, a 48 MP main camera and runs on the Qualcomm Snapdragon 860.
NFC Not Working After Battery Replacement
I changed the battery on my Poco X3 Pro and reassembled it, but I haven't glued the back cover. Everything works except for the NFC.
Do you know if the back cover needs to be glued for the NFC to work?
@chris13687 Do you know if the back cover needs to be glued for the NFC to work? No, that should not matter. Make sure that your antenna still makes contact and that there is no damage to it. Double check the contacts.
Chris crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 44
