My laptop is not turn on
@mauryasagar it is really hard to help you if you do not give us all the information. We really need more background. Let us know what happened and what you have already tried.
For now do this. Start off with the easy things. Disconnect the power from the computer by unplugging the power cord from your computer. Disconnect all external devices from the computer. Now hold the power button depressed for about 30sec-1min. Reapply the AC power adapter and see if your computer does show any sign of life.
First, you want to check your power supply. Make sure it has the proper voltages. Check to make sure that the connectors are not bend etc. Check the DC-in jack of your laptop. Make sure there is no corrosion, debris etc. that prevents it from working. Clean it of any debris etc, use a few puffs of air to clean it out. If none of this works, get a ammeter and see if your laptop draws any amperage from the charger. After that, you need to check and see if your motherboard even gets power. For that of course, you need to open it up. Post Some good pictures of what you see. That way we can see what you see.
crwdns2936753:030crwdne2936753:0 2
crwdns2942667:0crwdne2942667:0 39
What happens?
crwdns2934271:0crwdnd2934271:0 bananakat12345 crwdne2934271:0
