Water drains out onto floor
Top loading machine. The water drains out on floor
If you used the hose probably a leak?
@nancy24834 you did not give us a model number for your washer. It is possible that this is a leaking drain pump or a damaged drain hose. Time to turn it over and to have a look.
WHEN does it drain out????????????? Being more specific helps us a lot.
Any time - your external hoses, water valve
When it is filling - water valve, internal hoses, drum leak
When it is washing - water fill sensor is putting too much water in tank, drum leak
When it is emptying/spinning - water pump, drain hose
Nancy crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 8
crwdns2942667:0crwdne2942667:0 30
