Why My TV went blank and the audio is still on
My brother was watching the TV, its actually connected to the internet and all of a sudden it went blank and the audio was still on
@bukayo start of by letting us know the exact model number for your Hisense Tv. Next, try a couple of basic things. Turn the TV to a channel where you can hear the sound. Next, use a flashlight and shine the beam at an angle against the screen. Do that in a darkened room. See if you can make out shadows or shapes. If you do, then it is your backlight that has failed.
If you do not see anything, unplug your set and remove the back cover. Then visually check the boards for any obvious damaged components. Check all the wiring and unplug the wires and plug them back in, make sure they are properly seated. Post some images of all of your boards with your question. Use this guide Adding images to an existing question for that so we can see what you see.
Let us know what you find out.
crwdns2936753:030crwdne2936753:0 3
crwdns2942667:0crwdne2942667:0 18
