Apple's top-of-the-line smartphone for 2021. Released September 24th, the iPhone 13 Pro Max sports a 6.7" ProMotion OLED display, a new triple rear camera system, and 5G connectivity. Successor to the iPhone 12 Pro Max.
Following exactly as the guide said, screen cracked
The repair being done was a battery replacement on a previously never opened iphone 13 pro max. I was following the repair guide for the replacement battery exactly as it instructed. First off, the provided suction cup was not nearly strong enough. I spent almost 45 minutes frighting to get a good enough suction to even get the screen to lift slightly. I tried cleaning the screen and the cup with isopropyl, using tape on the screen (even though initially it wasn't cracked). It feels as though I need to be a professional power lifter to even get the screen up a fraction of a millimeter. Secondly, as soon as I was able to lift the screen enough to get my first pick under the screen at the bottom of the phone, the second I let off a little pressure on the suction cup, my screen cracked. is this normal? is it supposed to take a metric ton of force to get through the adhesive on the screen? I've done screen replacements before back when I worked for a phone repair store, but I've never had this much trouble getting the screen off before. Was it because this is the first time the device has been opened?
(of course the first time I ever crack a screen it would be on my personal device. The only reason I tried the replacemnt myself is because I couldnt afford the professional one, and now my phone is bricked.)
Hi,
I was caught off guard on my first 12 Mini display removal.
It turns out that Apple display seal is wider, thicker and takes more heating to penetrate past the seal.
This complicates things by having the seal let go on the Lcd above on the frame seal.
So what happened was I put the pick under the screen and not the screen frame, this led to lifting the Lcd off (breaking it) and leaving the frame still attached to the phone.
So now I make sure I have enough heat (without going too far and damaging the Lcd) and coming into the edge at more of an upright angle to make sure that I get under the frame seal.
Unfortunately you’ll have to replace the Lcd and hopefully it’s not bricked in the true sense.
Hope this helps
Thanks for the reply. Unfortunately my screen is completely inoperable, and I don’t have $20 to my name, much less the $400 it would cost to buy the lcd replacement. If I had even $60 to begin with, I would have taken it to the repair store down the road. Thanks again. Guess I’m going phoneless for the foreseeable future
Sorry to hear that, I hope good things do come your way.
All the best.
livewiki crwdns2934231:0crwdne2934231:0
crwdns2936753:07crwdne2936753:0 18
crwdns2936753:030crwdne2936753:0 59
crwdns2942667:0crwdne2942667:0 240
