I’m unsure what cable this is any idea?
I’m unsure what this cable is but it’s ripped my MacBook a1534 charges I feel the battery heat but not anything usual I doesn’t turn on or show the charging indicator
the last thing is my case on the corner is bent but the actual components are fine and working besides the cable is there a way to un bend it and is a small gap between the bottom case safe I don’t use it near drinks never have thanks
@aadendonia12088 that looks like your Audio Board Flex Cable, Apple part number 923-01003. "is there a way to un bend it" and "is a small gap between the bottom case safe" will depend on how bend out of shape it is and how small the gap is. You can always try and bend some of that back or leave it if it does not impede the function.
Looks like Apple's # 923-01003, Used for audio.
It appears the cable is damaged so you will need to replace it. The other folks have given you the parts info, here’s one source MacBook 12" Retina (Early 2015-2017) Audio Board Flex Cable
As to where the cable connects to on the logic board refer to Steps 23 thru 26 in this guide Retina MacBook 2015 Logic Board Replacement the image in Step 23 shows the cable already disconnected from the Audio board (finger pointing to it)
crwdns2886500:0This cable connects the audio board to the logic board.crwdne2886500:0
crwdns2934075:0crwdne2934075:0
$14.99
Aaden Donia crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 4
crwdns2942667:0crwdne2942667:0 104
