LG TV no screen after storm
Hi
Hi
My LG 32NL575v TV's screen no longer works since a recent thunder storm.
The sound is OK but nothing from the screen, not even faint when checking with a flashlight.
I have the back off and there's no visible damage to any components. It could be the T-Con board and replacements are available. Just wondering if there's a way to test it before buying.
Any help appreciated.
@danr99897 there is really not much of a test. It used to be that if you can still see your onboard menu then it was your T-con board. If you can't then it was your mainboard. That however has somewhat gone by the wayside. Now, the way I do it, is by measuring some of the more common voltages that you have to have on the T-con board for it to work. If those voltages are all present, it is unlikely that it is the T-con board.
Another thing you can try is to release the cables from the T-con board to the panel. Unplug the power cord, disconnect one ribbon cable from the T-con board to the panel, replace the power cord and turn the TV on. Anything? Repeat the steps but reconnect the previously disconnected ribbon cable. Anything? Let us know what you find out.
Not sure where in the World this TV is located but we really would need to see the boards and in particular the T-con board to see if it has test points for those voltages. Remember, OEM's don't want us to fix those devices, they want us to buy new stuff. that is why a lot of times the schematics etc. are not made public nor are the boards labelled.
Adding images to an existing question
Thanks for the reply.
In the UK. Have tried the TCON board test by unplugging the ribbons but still the same.
I've now been given a Samsung 32" TV so a repair isn't too important.
Testing and taking readings may take a bit of time so might put it on hold for now.
Replacing each of the three boards one at a time could be a waste of money too.
I may check the backlight strips though for any burned out LEDs.
DanR crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 175
