Why is my phone screen not clipping to rest of phone?
I did a repair, but it won't reattach.
This is a common problem; what's happened is you've detached the screen from its mounting frame instead of detaching the screen frame from the phone. Look around the outside edge of your new screen; you see that black frame surrounding it? That's the frame. If you check your old screen you'll see the black frame is missing; now look on the phone itself and you'll see the missing frame.
So the key here is to disconnect the screen, then go through the screen removal process again with your opening pick, only this time get the pick between the frame and the phone. Once you've gotten all the way around, the frame will come off and you can discard it.
Be sure to clean all the old adhesive off and apply a new sheet of precut adhesive and you should be all set to go.
Thank you very much! Btw, where is this frame coming from?
@parkere1 It comes attached to the screen and is supposed to be separated from the phone when you take the screen off, but sometimes people get their opening tool between the screen and its frame instead of the screen+frame assembly and the phone itself. When that happens they get the screen off, but it leaves the screen's frame attached to the phone. Of course, the replacement screen already has a frame on it so you can't put the new screen on because the old screen frame is in the way.
crwdns2942667:0crwdne2942667:0 79
