Repair and disassembly information for Logitech's G Pro X Superlight wireless gaming mouse. Identifiable by model number MR0106. Released in December 2020.
Scroll wheel not working after installing a replacement.
The middle click was not working on the mouse so I got a replacement. After the replacement, the wheel stopped working and the middle click didn't improve also. This was also the same with the old button board.
You say you got 'a replacement' but do not specify for what: a replacement for the 'middle click' sounds strange.
Two things can go wrong here.
  1. The middle click not working: If you open the mouse you'll find the wheel shaft rests on a small micro switch. Determine if it seats properly and if you can hear a 'click' sound when pressed.
  2. If the wheel doesn't scroll, here's what I found on mine: A plastic wheel with a soft plastic/rubber 'tyre' (or tire in American spelling) covering it. My tire was slipping on its wheel - both very smooth - and the tire wasn't a tight fit any longer. I roughened up the wheel a bit and dabbed a drop of super glue on the wheel bead then re-fit the tire - problem solved.
I replaced the hole button assembly the above is a link to what I bought
I also, feel the click
I can also feel the notches when I spin the wheel
james1998hodges crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 44
crwdns2942667:0crwdne2942667:0 250
