Model A1419 / EMC 2806 / Late 2014 or Mid 2015. 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (ID iMac15,1); EMC 2834 late 2015 / 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (iMac17,1) All with Retina 5K displays
iMac does not boot after SSD upgrade?
Found a nice Mac on FB marketplace. But advertised as suddenly slow.
But at £50, thought I’d give it a shot, I’ve always been happy building PC’s.
Blackmagic disk monitor was reporting 5mb/s, so disk was obviously the prime suspect.
Bought a 512gb NVMe, and the Sintech adapter.
Decided to remove the hdd entirely and the sata cable, and swap the existing 32gb blade ssd for the new, larger one.
Looked at the forecast, rain all day.
Decided to spend a morning taking apart my new iMac, installing an SSD and defluffing it.
Followed the comprehensive iFixit guide online, and quite enjoyed taking a nicely built machine apart. Then putting the cleanest Mac in England back together.
Then it wouldn’t turn on.
Take it all apart and check my work.
All back together again. Still nothing.
Start checking PSU with a multimeter. Seems to be supplying 12v to the logic board.
Perhaps it’s a conflict with the ssd/removing the Sata cable?
Put it all back to standard, exactly as it came to me.
Nothing. Sweet FA.
In frustration I put the last few bits back in, and forget to unplug it.
Scare the wife by giving myself a fairly good wallop from the back of the PSU. Definitely supplying power to the logic board.
It’s now 6 o’clock, and I’ve been cocking about with this since 9am. And the sun came out around 4, but I was determined to finish it.
It’s now in the spare room, cos I’m not spending £120 on a second hand logic board.
FML.
What is your exact model? The early 2012/2013 systems require a mSATA blade drive here’s a good reference on Apples custom blade SSD’s The Ultimate Guide to Apple’s Proprietary SSDs if you have a newer NVMe version then you need to install High Sierra or newer as the Firmware update and the updated macOS have the needed support for NVMe drives.
Why didn’t you just replace the failing HDD with a SSD? There is no speed difference in the SATA interfaces, and the SATA SSD will be quite fast over the older HDD.
Late 2015 3.2ghz i5, 24gb RAM 27” 5k Retina screen. Monterey OS.
From what I’ve read, an NVMe drive seems to offer nearly 2000mbps, whereas the older style Sata SSDs seem to be 500-800mbps?
Regardless, it’s more the fact I have no response from the logic board after refitting everything?
Is there a secret switch or something? Some very common part that’s dies easy?
Or have I killed the whole logic board?
@ianedwards76 - While some M.2 SSD’s can run 2.0Gbps, most can’t or only in read not write using testing tools not real life, and the given version of PCI the system and the drive have. Your system offers a PCIe 3.0 x4 interface. So make sure the SSD you bought is also PCIe 3.0 x4 the newer PCIe 4.0 SSD will likely not work unless it’s spec’ed to be downwardly compatible.
As far as parts failing, I’m not a lover of these M.2 adapters in iMac’s given how much work it is to get to it if you have problems.
@ianedwards76 just to clarify, at no time do you get any of the diagnostic LED's to turn on? Have you checked for power on the logic board? HAve you checked the logic board for any power? I suggest you give this one mor try and follow this IMac27 Late 2015 No Power. that way we are all on the same page and know what has already been checked.
Definitely no status LEDs are on.
232v AC power at PSU input, 12v at PSU output.
Checked on the pins at the reverse of the logic board 12v socket, they are definitely 12v too.
The board is receiving power. 100%.
OK, I think I see the issue! Your system was a Fusion Drive’d model with two drives the NVMe blade as well as a SATA HDD.
Correct me if I’m mistaken your system is responding you get the bong then just getting a blinking question mark in a folder icon or your system fully dead?
If you are getting the blinking question mark in a folder you’ll need to use a bootable external drive to enter into Disk Utility to reconfigure your drive. As the system is still expecting the Fusion Drive.
If the system is not responding then something didn’t get reconnected or was damaged in the process. Did you follow this guide? iMac Intel 27" Retina 5K Display Logic Board Replacement the process of taking the display off is the most critical as it’s very easy to damage it or the cables.
It’s fully dead. No bong when pressing the power button. No response at all.
No status LEDs lit whatsoever.
When putting a multimeter on the PSU I can see the AC voltage on the board. I can also a 12v DC output, and it appears at the pins on the back of the logic board. So I know the logic board is receiving some power. That’s about the limit of my testing ability?
I did follow the iFixit guide, and was very careful. The board must be very fragile as I feel I was meticulous? :(
@ianedwards76 - Check your cable connections like the power button.
Yes, checked the power button, all works as expected. Shorted the pins on the PSU too, just in case, but still no action from the logic board lights.
@ianedwards76 - Sadly that only leaves the possibility of damage within the logic board. Carefully review the areas you touched for damaged or missing SMD devices. You might have snagged one while messing about.
ianedwards76 crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 35
crwdns2942667:0crwdne2942667:0 254
