Repair information and guides for the iPhone 8 that was released on September 22, 2017. Model: A1863, A1905
How to change front glass lens
It's one of those if you need to ask, you can't do type of operation.
If you insist, here is the general breakdown:
  • Remove the screen assembly from the phone and remove critcial parts like the home button, ALS/top speaker flex and so on.
  • Cut open the plastic screen frame and pull it off the glass.
  • Use thin molybdenum wire to cut through the LCD optical bonding to the panel so you can separate the panel from the glass.
  • Use solvents to wash the remaining optical bonding from the LCD panel.
  • Apply new optical bonding adhesive to the LCD panel.
  • Attach the LCD to the new glass panel, align it properly and avoid trapping any debris between the bonding.
  • Use a vaccum lamination machine to properly bond the optical bonding layer to remove any air bubbles.
  • Adhere a new set of screen frame onto the glass.
  • Reassemble critical parts and the whole phone.
Basil Kurian crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 68
