Mengapa perangkat handphone saya tidak dapat mengisi daya
Tidak dapat mengisi daya pada saat dicharger
Translation Indonesian - English
Why my mobile device won't charge
Can't charge when charger
@onjunkmang must be something in the air. We have had multiple of the "no charging" questions today :-)
Anyhow, let us know if anything happened to your phone. Things like water damage or having dropped the phone etc. makes a difference. It is also really helpful, if you can tell us what you have checked and what you have tried to fix it. That way we do not repeat ourselves and bore you with our answers.
First check your charger. Make sure it is in good working condition. Then check your charging cable. Check to make sure that the connectors are not bend etc. After that, check the charging port. Clean it of any debris etc, use a few puffs of air to clean it out. If none of this works, get a USB ammeter and see if your phone draws any amperage from the charger. If it does not, it is possible that this is a charging port issue or a bad battery.
Time to open it up and to check things out. Since iFixit does not have a specific guide for this yet, use something like this video Check the charging board for any obvious issue. then check the flex cable which connects the charging board to the main board. Make sure there are no tears etc. and that it is properly connected. To check your charging port use a voltmeter and measure the voltage on your battery connector. Next plug your phone charger in. Now measure the voltage on your battery connector. That voltage will have to have increased. If not then the issue is either the port or the charging circuit.
I personally find it a lot easier to just replacing the charging board. It is relatively inexpensive and easily replaced. That usually increase the chances of fixing the issue.
Translation
@onjunkmang pasti ada masalah. Kami menerima banyak pertanyaan tentang "tidak bisa mengisi daya" hari ini :-)
Bagaimanapun, beri tahu kami jika terjadi sesuatu pada ponsel Anda. Hal-hal seperti kerusakan akibat air atau ponsel terjatuh, dll. dapat memengaruhi. Akan sangat membantu jika Anda dapat memberi tahu kami apa yang telah Anda periksa dan apa yang telah Anda coba perbaiki. Dengan begitu, kami tidak akan mengulang-ulang dan membuat Anda bosan dengan jawaban kami.
Pertama-tama, periksa pengisi daya Anda. Pastikan pengisi daya dalam kondisi baik. Kemudian, periksa kabel pengisi daya Anda. Pastikan konektornya tidak tertekuk, dll. Setelah itu, periksa port pengisian daya. Bersihkan dari kotoran, dll., gunakan beberapa semprotan udara untuk membersihkannya. Jika tidak ada yang berhasil, dapatkan ammeter USB dan lihat apakah ponsel Anda menarik arus listrik dari pengisi daya. Jika tidak, mungkin ini masalah port pengisian daya atau baterai yang rusak.
Saatnya membukanya dan memeriksa semuanya. Karena iFixit belum memiliki panduan khusus untuk ini, gunakan sesuatu seperti video iniPeriksa papan pengisi daya untuk masalah yang jelas. lalu periksa kabel fleksibel yang menghubungkan papan pengisi daya ke papan utama. Pastikan tidak ada sobekan, dll., dan terhubung dengan benar. Untuk memeriksa port pengisian daya, gunakan voltmeter dan ukur tegangan pada konektor baterai. Selanjutnya, colokkan pengisi daya ponsel. Sekarang ukur tegangan pada konektor baterai. Tegangan tersebut harus meningkat. Jika tidak, maka masalahnya ada pada port atau sirkuit pengisian daya.
Saya pribadi merasa lebih mudah untuk mengganti papan pengisi daya. Biayanya relatif murah dan mudah diganti. Itu biasanya meningkatkan kemungkinan memperbaiki masalah.
crwdns2936753:030crwdne2936753:0 4
crwdns2942667:0crwdne2942667:0 50
