The camera lens won't connect!
I can take pictures with manual operation, but the screen is black!
Even after replacing the lens, it's the same, and it's a camera problem!
What should I fix?
What should I fix?
@w08yt9heklnkrhu you are not saying if it is just the screen that is black, but you can still take pictures. If you can do that the issue will be the LCD screen. If the pictures are black as well, then the issue is most likely a bad image sensor. Check this guide for that Disassembling Nikon D3000 - iFixit Repair Guide
@w08yt9heklnkrhu remove your lens and check the contacts on the camera body and the lens. Clean the contact points on the lens and the body. Try reattaching the lens. While you do so, make sure that the contacts line up.
The LCD screen works fine! The pictures I take are black and very underexposed, but I want to solve the problem of the lens not connecting first!
crwdns2936753:030crwdne2936753:0 6
crwdns2942667:0crwdne2942667:0 77
