The Xbox 360 is the second game console made by Microsoft, and was released November 22, 2005.
How to fix "unrecognized disk"
this just happened to me today. i opened it and cleaned it out and it still wont work. every time i put a disk in, it says unrecognized disk. i want to fix it but i already fixed it for red rings so I don't want to put anymore money into it. besides ps3 (even ps2) is better than xbox!
when you say cleaned it out, what did you clean out?
Zane, the first thing I would suggest is that you clean the laser. you can purchase a DVD cleaning kit at most department stored. Should you have no luck finding one, you ill have to disassemble your optical drive. Here is how to get it out, and on here you can see how to disassemble the individual drive. Make sure you select the right optical drive, there are a few different ones. Once cleaned you can try it and see what happens. If the cleaning did not help, you can try a Pot adjustment. Great instructions are downloadable from here. Be sensible with the adjustment. If you are not up to that, you can of course also replace the laser assemble, or the whole drive. Just remember that "Xbox 360 is designed so that the DVD drive works only with the particular game console it is installed in". So you will have to reflash it or keep your original PCB and replace your drive with the same model, and switch the PCB over. Hope this helps, good luck
I brought a cleaning DVD for my.Xbox and it doesn't read and my black ops 3 doesn't read ether
&&^& you @%^$$@$# all of you
Your &&^&^$^ shyts broke you got it good go cry and die or buy my product u son of a ##&&%
Zane crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 4
crwdns2942667:0crwdne2942667:0 14,937
