ASUS VS248HR Screen does not work
  • My ASUS screen does not connect. When I turn my pc on it shows an orange light. It is connected to my pc and has worked previously but does not work anymore.
Hi @jellybeanman
Try connecting another monitor to the PC and check if it works OK.
This is just to isolate whether the problem is the PC or the monitor.
Have you tried a different known working cable between the PC and the monitor?
Can you try using a different connection type cable between the PC and the monitor to what is used now e.g. HDMI, DVI or vga to see if the monitor now works?
What have you tried?
