Released in January of 2020, the Dell XPS 13 9300 is physically very similar to previous models but has optional upgrades for graphics and the processor.
Black screen following Dell logo
Following a windows upgrade my laptop goes to a black screen after the Dell logo. All the suggestions on line are not helping, and I can't seem to start in safe mode. Anyone else having this problem?
Any suggestions welcome.
Hi @phgs
If you haven't already done so try entering the WRE (Windows Recovery Environment) menu.
To do this, turn on the laptop and when it boots into Windows, force stop the laptop by holding the Power button until it shuts down.
Do this 3 times, i.e. Power on > boot > force stop > power on > boot > force stop etc.
On the 3rd attempt it should boot into the WRE.
Select troubleshooting > advanced > Startup repair and follow the prompts.
If this doesn't work use the same procedure as before to get into WRE and select either the system restore point option or the system image option (if you have them that is)
DO NOT select the Reset this PC option because if you select the wrong option next it will erase all your data and reinstall Windows.
If you can't get into WRE for whatever reason, you can create a Win10/11 recovery USB from any known working Win10/11 PC. You'll need an 8GB USB flashdrive and about 60 minutes of time to create it. In the host PC, go to Control Panel > Recovery and find the create recovery drive link - You should make one yourself when your laptop is working and keep it safe in case of future problems.
When you have the Recovery USB drive, insert it into your laptop and then when you start the laptop press F12 to select the USB drive as the first boot option and then restart the laptop . If it doesn't boot from the USB go into BIOS and enable Legacy USB function in the settings.
Hi @jayeff,
Thank you for replying.
I have tried the force stop cycling g to enter WRE, and nothing happening. Sigh.
Now I am seeing 2 amber and 7 white flashes, so an LCD issue. (I may have missed this previously- shrug)
Now to.try the recovery USB.
TVM
I may need a XPS 9300 display. Do you have these?
PHGS crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 51
crwdns2942667:0crwdne2942667:0 462
