The PlayStation 3 (or commonly known as the PS3) is the third home computer entertainment system produced by Sony Computer Entertainment, and the successor to the PlayStation 2. It was released November 11, 2006
Ps3 blue ray drive problems
Ok so I had a ps3 fat cechopo1 and it worked fine before but after I took apart and put it back together my blue ray disc drive no longer took any disc a blue light appeared on the ps3 and when I tried to push the disc it the mechanism did not pull it in nor push it back out what is the reason for that I tried to replace the blue ray drive multiple times but the results where always the same
Hi Carmine!
Could be a lot of things to be honest!
Please check the PS3 drive - motherboard ribbon cable (you can test the cable by doing a continuity test on both ends, if it beeps, it’s OK).
Also check the drive it’s power cable.
This issue is common and it could be the drive it’s mechanism which is broken.
I saw this issue sometimes and replacing the drive for another one does work. Make sure to transfer the old drive it’s PCB to the new drive!
If this didn’t solved it, then it’s most likely something on the motherboard (transistor, or something else)…
Please let us know your findings! Good luck!
Carmine Varrone crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 240
