Released in November 2017, the Oppo F5 is the first smartphone to use an 18:9 display instead of 16:9. In spite of having a 6.0-inch screen, the F5's width is similar to the 5.5" display with 16:9. Models CPH1723 and CPH1727.
Mengapa ketika saya telepon layar hp mati
Mengapa layar HP saya mati ketika di buat telepon
hai, berikut informasi yang dapat Anda ikuti untuk melihat apakah Anda dapat memahami dan memperbaiki masalah tersebut. Anda mungkin harus menggunakan Google Translate.
https://www.geekinstructor.com/fix-scree...
semoga ini membantu
semoga ini membantu
hi, here is information you can follow to see if you can understand and fix problem. You may have to use google translate.
There are several steps to try that may fix your issue.
hope this helps
Proximity sensor issue.
Yakınlık sensörü sorunu umarım yardımcı olur, ayarı değiştirmek için ekrandaki okları takip edin.
https://youtu.be/eaVJUUpJ7UY?si=3A3_gdRb...
Lathoif 123 crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 6
crwdns2942667:0crwdne2942667:0 138
