The Mercedes-Benz W126 is a series of S-Class automobiles manufactured by Mercedes-Benz between 1979 and 1992. Premiering in September 1979 as the successor to the W116 line, the W126 was the second generation to officially bear that prestigious designation, an abbreviation for the German Sonderklasse or "special class." The W126 was initially offered with straight-six, V8, and a turbocharged diesel engine for the sedan. A C126 2-door coupé versions was introduced in September 1981.
280se turns off on its own
Why will my 280se wouldn’t pull and then engine turns off on its own
From what you've provided your transmission could be seized which would choke your engine out, you could have a computer issue or more.
Before anyone can help you're going to have to give a bit more information:
  • Is this vehicle a daily driver and it just started happening or a barn find?
  • Are the vehicle fluids at the correct level and correct color?
  • Is the parking brake engaged?
  • Is your battery charged enough to maintain engine operation?
  • Are you able to put the vehicle in gear?
  • Is the engine idle erratic? ( surges or lack of fuel die off)
  • Are there any weird noises?
  • Have you looked under the vehicle to ensure there's no: transmission, drive housing, engine case damage; blockages preventing movement; weird smells?
If you could provide the steps you have taken, sounds you hear, smells you smell, and observations made as a list it would be helpful (and frustrating on your end I'm sure) to troubleshoot your vehicle.
wan wisa shephards crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 4
crwdns2942667:0crwdne2942667:0 69
