My charger port is damaged what should I do
My charger port is damaged what should I do it's volume button also broke
Hi Sharda,
Although I'm not 100% sure exactly what the difference between your tablet and the M10 HD version, I'm hoping these guides will be close enough to let you fix your tablet.
First off, on the M10 HD (and hopefully yours as well), the charging port is mounted on a daughter card that can be fairly easily replaced. Here's a guide showing you step by step how to do that job.
Manuales / Lenovo Tab M10 HD / Auxiliary board
With regard to your volume button, it depends what part of it is broken. There's the physical button you push, then there's a tiny circuit board with the electrical switch mounted on it. Both of those are fairly easy to replace, but have different guides for each procedure.
Manuales / Lenovo Tab M10 HD / Side push buttons
Manuales / Lenovo Tab M10 HD / Side keys
The first one is for the electrical part and the second guide is for the buttons themselves.
Hopefully that will give you the information you need. With regard to parts, your best bet is to search on sites like Amazon, eBay and AliExpress for your model number together with the name of the part, although if you're okay with shipments from Spain you can order two of those parts through their website.
It isn’t that charge port board I looked it up earlier, there’s a lot of models and revisions. The board needed is a different I’m 80% sure. Why I asked for a model number.
I can’t see anything on here. Can you give me the exact model number. I’ll link you to what you need.
Sharda Sharma crwdns2934231:0crwdne2934231:0
crwdns2936753:07crwdne2936753:0 19
crwdns2936753:030crwdne2936753:0 85
crwdns2942667:0crwdne2942667:0 900
