Apple's top-of-the-line flagship for 2022. Released September 16th, the iPhone 14 Pro Max sports a 6.7" ProMotion OLED, the new Bionic A16 chip, a triple rear camera system, and 5G connectivity. Successor to the iPhone 13 Pro Max.
Water damage, phone keeps restarting every 3 minutes
I showered with my phone and there is condensation in my front and back cameras. My phone turns on but restarts every 3 minutes. It has been 3 days since the water damage. What are my iPhone Kernel Panics telling me?
Hi @plantsss
Try to repair any water damage first before worrying about the kernel panics.
The impurities in the water causes corrosion and provides circuit paths for the electricity which were not in the phone's operating design and could damage the components. The corrosion starts immediately and is ongoing until it is completely cleaned away
First do not try to charge or to turn on your phone and then remove the battery as soon as possible to minimize any further damage.
Then you need to dis-assemble the rest of the phone and clean all the affected parts using Isopropyl Alcohol 99%+ (available at electronics parts stores) to remove all traces of corrosion and water. If possible do not use "rubbing alcohol" as in some cases this is only 70% IPA or less, can contain additives which may leave conductive residues and is not as effective. If you do have to use it check the label to verify the amount of IPA. The higher the percentage of IPA the better
Here is a link that describes what happens. Electronics Water Damage
As always with electronics, especially surface mounted pcb be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board. Remove the shields that may be covering some components as the water may have got in under there. The ends of any flex cables and their connectors need to be cleaned as well
Hopefully after you have done all this the phone might possibly work correctly again.
Here is the ifixit iPhone 14 Pro Max repair guide that may help
If this process seems too daunting, take your phone to a reputable, professional phone repair service, experienced in liquid damage repair and ask for a quote for a repair. If you decide to do this, do it sooner than later.
Keep in mind, it's not always recommended to repair a liquid damaged device as it can be a gamble and there's no way of telling how long it'll last. Some repair shops may be willing to fix it, and others may not, and there may not be a warranty with the repair. And just because a device is rated to be "water proof" or "liquid resistant" doesn't guarantee the seals will hold up.
Here's a guide to reading the panic logs from VCC Board Repairs https://youtu.be/kTeOARF5HNc?si=ar0OwIaH...
If you need your data, you can send the device to them. Good luck!
Plants crwdns2934231:0crwdne2934231:0
crwdns2936753:07crwdne2936753:0 21
crwdns2936753:030crwdne2936753:0 83
crwdns2942667:0crwdne2942667:0 520
