This ASUS laptop is identified by its model number, A53S, which can be found on the bottom of the laptop in the top left corner. It was produced in November 2011 with a multitouch gesture touchpad and a 6-cell lithium-ion battery.
How to fix female charging port?
how to fix my laptop is not charging?
Take it to a repair shop. You could replace the connector if your good at soldering or buy a replacement motherboard even off Ebay for about £60. It might not be the connector though it could also be something that’s blown on the board that’s stopping it working so self repair could end up being a rabbit hole.
Hi @kyleburat
Here's the ifixit Asus A53S Motherboard Replacement guide that will help.
You will need to remove the motherboard from the laptop so that you can unsolder the DC-In jack from the motherboard and then solder in the new one in its place.
Search online for Asus A53S DC-In jack (supplier examples only) to find suppliers that suit you best.
Yes agreed DC Jack replacement certainly worth a go especially if it looks damaged or is loose.
kyle burat crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 8
crwdns2942667:0crwdne2942667:0 53
