Random power offs, bluescreens and low performance
Hello
My laptop randomly powers off or get bluescreen with errors like:
1)Driver_irql_not_less_or_equal
Netio.Sys
2)kernel auto boost lock acquisition with raised irql
3)attempted execute of noexecute memory
nvlddmkm. Sys
4)kmode exception not handled
5)kernel security test failed
6)memory management
7) irql_not_less_or_equal (not same as 1))
The most common are 1), 7), 4)
Also the performance of the laptop is low, it's not overheating. Sometimes it drops performance up to bare minimum for 2 seconds while playing as basic thing as homm3. At the same time it holds up baldur's gate 3 at some decent level.
age of the laptop is not the problem
I have the same problem since december 2024, do you found any solution?
First place to look is a corrupted driver.
This is a simple first line to try for minor driver problems.
Open Device Manager. Display adaptors is a good place to start. Click on it and it will open to your video card. Right click and select "uninstall device". When the next windows opens do not check the "Delete the driver software for this device." Just select "Uninstall" box.
Your screen will look wierd for a short while but when it settle down go to top of Device Manager, click on "Action" and select "Scan for hardware changes." This will do a quick reintstall.
Reboot and see if this fixes the problem. If not go through some other devices such as Network adapter, etc.
But with errors like the "nvlddmkm.sys" I would try completely uninstalling the display adapter drivers. Nvidia in your case?
The best app for this is the freeware program DDU
(Display Driver Uninstaller).
It completely clears out everything to do with your GPU/Display Driver/Video Card Driver - whatever you want to call it.
Read their directions first - don't rush it!
I have fixed many strange problems with this in the past. Corrupted drivers will mess up memory access, settings, etc., etc.
Piotrek Gejgał crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 169
