Released Late August of 2021 Made By Samsung MSRP: 160$ CAN
Mengapa hp Samsung ini mati total charger tidak masuk
Layar tidak tampil ketika di charge
Translation Indonesian - English
Why is this Samsung cellphone completely dead, the charger doesn't go in?
The screen doesn't appear when charging
@dedehindun the screen may not appear since your phone might not be charging. you did not tell us if you have checked the charger and charging cable. First check your charger. Make sure it has proper output. Then check your charging cable. Check to make sure connectors are not bend etc. After that, check the charging port. Clean it of any debris etc, use a few puffs of air to clean it out. If none of this works, get a USB ammeter and see if your phone draws any amperage from the charger. If it does not, it is possible that this is a charging port issue or a bad battery.
To check the charging port, disassemble your phone. Use a voltmeter and measure the voltage on your battery connector. Next plug your phone charger in. Now measure the voltage on your battery connector. That voltage will have to have increased. IF not then the issue is either the port or the charging circuit. You may need to replace the charging board as well as the battery.
The A series has issues with the flex cables coming from the charging board to the main board. Check that for micro tears and corrosion and proper connection to the boards. I suggest that you start with a new battery if any of the above did not work. After that it's the charging board and flex cables.
Since iFixit does not yet have a specific guide for this, use something like this video Replacement charging board and batteries are readily available at many online stores.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has a device with the same issues as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
Translation
@dedehindun layar mungkin tidak muncul karena ponsel Anda mungkin tidak sedang diisi dayanya. Anda tidak memberi tahu kami apakah Anda telah memeriksa pengisi daya dan kabel pengisi daya. Pertama, periksa pengisi daya Anda. Pastikan outputnya sesuai. Kemudian, periksa kabel pengisi daya Anda. Pastikan konektornya tidak bengkok, dll. Setelah itu, periksa port pengisian daya. Bersihkan dari kotoran, dll., gunakan beberapa semprotan udara untuk membersihkannya. Jika tidak ada yang berhasil, dapatkan ammeter USB dan lihat apakah ponsel Anda menarik arus listrik dari pengisi daya. Jika tidak, mungkin ini masalah port pengisian daya atau baterai yang rusak.
Untuk memeriksa port pengisian daya, bongkar ponsel Anda. Gunakan voltmeter dan ukur tegangan pada konektor baterai Anda. Selanjutnya, colokkan pengisi daya ponsel Anda. Sekarang ukur tegangan pada konektor baterai Anda. Tegangan itu pasti sudah meningkat. JIKA tidak, maka masalahnya ada pada port atau sirkuit pengisian daya. Anda mungkin perlu mengganti papan pengisi daya dan juga baterainya.
Seri A memiliki masalah dengan kabel fleksibel yang berasal dari papan pengisi daya ke papan utama. Periksa apakah ada sobekan mikro dan korosi serta sambungan yang benar ke papan. Saya sarankan Anda mulai dengan baterai baru jika salah satu cara di atas tidak berhasil. Setelah itu, baru papan pengisi daya dan kabel fleksibel.
Karena iFixit belum memiliki panduan khusus untuk ini, gunakan sesuatu seperti video ini Papan pengisi daya dan baterai pengganti tersedia di banyak toko daring.
Saat Anda mengerjakan ponsel, ambil banyak gambar. Setelah selesai, ambil gambar tersebut dan buat panduan untuk iFixit. Itu akan membantu orang berikutnya yang memiliki perangkat dengan masalah yang sama seperti Anda. Membuat panduan ini mudah dan menyenangkan. https://ifixit.com/Guide/new Komunitas iFixit akan menghargai ini.
Perbaikan adalah Perang terhadap Entropi!
Dede Hindun crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 6
crwdns2942667:0crwdne2942667:0 68
