No picture but backlight running
I got this broken TV from a friend who suspect it broke from a lighting strike but not too sure. When i first plugged it in it started and turned on. It would show picture and everything but when you used the remote and selected or moved to different pages or menus it would completely kill the backlight like it was drawing to much current or something, going back or the another menu would make come back as if nothing had happen. This med me think that there was a problem with T-Con Board, i removed it had a look at it then put it back. After doing that the TV all out sudden worked flawlessly except for the internal speakers, no big deal i used the TV with a Bluetooth speaker and watched something to test it for a couple of hours after about 3 hours it completely died. Restarted it and the only thing that happens is that after plugin it in the backlight fires up but no picture and not even the indicator light works. The only thing a noticed when i tested it while it was working was that the CPU and the chips on the T-Con Board was maybe a tad bit on the hot side, but I'm not to sure how hot they should be.
The only thing a can think is broken is power board but i need further assistance to find the fault, what is the next thing to check any specific voltages to check?
TLDR: No picture (not even the logo), [s] backlight starts running by it self after plugin in [s] *not anymore, bad Power Supply Board?
****UPDATE***
Now i don't get anything when pluging it in (no backlight, no indicator etc.), used AI to help me and guide me through the fault finding process, it thinks its the PSU as i get a high PSU_ON signal even when i haven't pushed the power button and still no 12v. Found this service manual.
Whoa, just realized the age on this. Not sure why it was high up on the Answers list :-)
Anyhow, I will leave it as a general answer @linushg you had a lot going on there. Got to start somewhere :-) As always, I would start by checking the power supply. See if you get the voltages indicated on the 3 components (PH002, PH003, PH004) between the primary and the secondary site of your power supply. Of course, check the fuse F6101 as well to make sure it is still functioning. After that, you will need to check if your power supply provides the standby voltage to the main board. You can do that on the connector where the main board plugs into the power board. When posting images it is important that they are well focused and large enough so we can see the reference numbers (i.e. CN201 as well as the legend that goes with those connectors) Here we can't see the legend for that connector (to small of an image ;-) so we can't give you the pin number. There should be 3.3V-3.5V on that pin. The Standby line is typically a constant voltage (usually $3.3 to 5V DC) that is always present when the TV is plugged in. If it does not, then it is pretty much the power supply that has failed.
As for using AI, remember that it gets its information from a vast dataset of text and code from publicly available sources like websites, books, and Wikipedia, which it was trained on. Basically that means it just gets information and regurgitates this. It does not think, it does not read schematics, it does not have any real experiences. It reads and analyzes existing information and it makes the rest up. I would not even be surprised if half of what it tells you actually comes from iFixit sources :-)
Linus Höggren crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 222
