Announced on October 13th, 2020, the iPhone 12 mini is a smaller version of Apple's iPhone 12. It features a 5.4-inch OLED display, an A14 Bionic processor, and dual rear cameras.
iPhone Green/White lines? Is it Fix Abble?
Helloe.
As you can see in the Picture i got some White and Green lines. But when i tap on the display 80% of the lines disepare. Is it fixeble or what can cause this problem? is it becuse of heat? it happend when i heated the display and as you can see the display (ram) doesnt loosen all the way.
/ Markus
You have to change screen
ive seen video when they turn heat on it and fix it. Goona try that first =D
@markooz86 did it work?
@nancy86234 If it did he would have excitedly shared the good news long ago.
@nancy86234 Nancy, if your screen looks like his then it's damaged and there's no fix beside replacing it. In this particular case, I believe the damage occurred because he didn't separate the screen correctly; the metal frame that's supposed to be mounted on the OLED is still stuck to the phone itself, so he got between the screen frame and the screen instead of the screen frame and the phone. Doing that makes it all too easy to damage the display because you're prying on delicate electronic connections instead of a metal frame.
Thanks Jerry!
Torn display flex cables, you need a new display.
Markus crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 115
