Difference between LM270WQ1 (SD)(F1) and LM270WQ1 (SD)(F2) displays
I removed my cracked display and the part number is LM270WQ1 (SD)(F2). I have found a LM270WQ1 (SD)(F1) display for sale and I was wondering if I could use it with my iMac 27-inch, Late 2013 (A1419) (EMC 2639)? Is there is any difference between the two displays?
@amak7922647 the LM270WQ1 (SD)(F1) is for the late 2012 and the LM270WQ1 (SD)(F2) is for the late 2013. The connectors as well as the connections, are identical on both. There might be differences in the colors, gray scale etc. but it should really not impact the compatibility. Here is LM270WQ1 SDF1 Datasheet I do not have the one for the at datasheet for the LM270WQ1 (SD)(F2)
The only difference I can find on Panelook is the storage and operating temperature. The (F2) can tolerate lower temps ;-)
amak79 crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 210
