Announced on October 13th, 2020, the iPhone 12 mini is a smaller version of Apple's iPhone 12. It features a 5.4-inch OLED display, an A14 Bionic processor, and dual rear cameras.
iPhone 12 mini cell signal low
more info
the bad reception is on AT&T and T-Mobile, i just tried with a verizon sim and i get good reception., still no reception with AT&T or Tmobile.
so, it looks like wifi-calling is helping with this.
this is my son's phone. He complaint that the cell signal is very weak, started about 3 weeks ago. I finally go around to check it out and using the field test, i see the rsrp is -120, which when i google, its very bad signal strength. Is there anything i can do to fix it? Is it the cell antenna that i can change?
Hi,
There’s no indication about where this problem occurs (home only, local area only or when in certain areas).
If the phone has had water ingress then you may be correct, the antenna may be starting to corrode.
First thing I would check is the SIM card for oxidation/wear, quick test would be try another known good SIM, but cleaning may resolve issue or replacing worn SIM
If no change then check for iOS updates, if already up to date then try resetting network connection in settings or restarting the phone.
If no change then look at opening up phone and visual inspection for water ingress around antenna components, or take to repair shop for assessment.
Hope this helps
Charles crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 100
