First generation, based on the Ford C1 global platform.
How to change Gasket seal
2004 mazda axela. Engine leaking I have seal but not sure how to replace
Hi robyn,
Can you be a little more specific? Exactly which seal did you buy? There are several on any given engine, so it's important to know which one you're trying to change.
  • Prepare the Vehicle: Park on a level surface, disconnect the battery, and ensure the engine is cool.
  • Locate and Access the Gasket: Identify the leaking gasket, and remove any parts obstructing access.
  • Clean the Surface: Remove old gasket material and clean the area around the gasket.
  • Install the New Gasket: Place the new gasket in position. Apply sealant if required.
  • Reassemble and Check: Reinstall removed components, tighten bolts to specifications, and check for leaks after starting the engine.
This looks like a typical AI generated answer to me; reasonably accurate yet at the same time pretty much totally useless.
ok cool thanks
robyn alker crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 117
