The 3rd generation iPhone SE was announced on March 8th during the Peek Performance Apple event. It features an A15 chip and a 4.7-inch LCD display, similar to its predecessor, the iPhone SE 2020.
Replaced screen but not working
Old screen now not working either
All connectors look fine
Please help
So after doing some googling it was as simple as doing a reset, it has now sprung into life.
Awesome, Justin; glad to hear it was something simple.
Hi Justin,
You've got an iPhone with a screen made with older LCD technology, which means it has a backlight. It would be worth your time to check to see if the backlight has failed. Take a flashlight and hold it up against the screen and see if you can make out an image. If so, you may have blown a backlight fuse on the motherboard, which would be a tricky repair for us home DIY-ers. That sort of thing usually happens when the screen is connected or disconnected while the battery is plugged in; it rarely is a problem when the battery is disconnected before working on the screen.
Check that out and let us know what you find.
Does the phone appear to be alive in other respects? Does it make any sounds or vibrations when turned on or connected to a charger? Is there a response when plugged into a computer; does the computer recognize that it's there?
Thanks for your help, but all it needed was a reset.
Justin Short crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 100
