The Dodge Dakota (called the Ram Dakota for its final two years of production) is a mid-size pickup truck from Chrysler’s Ram division (formerly called the Dodge Truck division). The second-generation Dakota began development in 1991, though they were not introduced until 1996 for the 1997 model year.
How to remove and replace the heater fan
How do I replace the heater fan motor
  • Disconnect Battery: Unhook the negative battery cable.
  • Remove Glove Box: Unscrew and take out the glove box.
  • Access Blower Motor: Remove any covers or panels blocking the motor.
  • Replace Motor: Unplug the old motor, remove it, and install the new one.
  • Reassemble: Put everything back together and reconnect the battery.
  • Test: Turn on the vehicle to make sure the new motor works.
It was my fault that it was wrong. I should have told you that the truck is a 4 door model , 4 wheel drive, V8 motor. It is different than the two door truck.
Ronald Brake Trotter crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 121
