Released 2020 with Snapdragon 720G SOC Sold in India as the Note 9 Pro Max
Allegedly Stuck in 2G.
Hi all.
I'm a trucker so i use my device constantly and always with data on. After a light incident in which the device fell on the truck floor my connection is terrible.
When I say terrible i mean it works fine sometimes (i should say under certain antennas) and has no data signal in other areas.
My ISP supposably did an extensive check and after 2 weeks the answer was my device is stuck in 2g, even though i sometimes have normal service.
Troubleshooting I have done so far is I took a new SIM card and even tried another ISPs and i had no change.
Should I try to change my data chip?
go to settings and check for sim settings and from there select your sim and then if you check you can see a setting called preferred network go there and select the required network option
xxdwbxx crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 99
