have sound but the picture does not display
My sansui TV have sound but the picture does not display
@prettymaleho we will need to know the exact model number for your TV. First do this, turn the TV to a channel where you can hear the sound. Next, use a flashlight and shine the beam at an angle against the screen. Do that in a darkened room. See if you can make out shadows or shapes. If you do, then it is your backlight that has failed. If you do not see anything, unplug your set and remove the back cover. Then visually check the boards for any obvious damaged components. Check all the wiring and unplug the wires and plug them back in, make sure they are properly seated. Post some images of all of your boards with your question. Use this guide Adding images to an existing question for that so we can see what you see. It is possible that this is either a power board or a T-con board issue.
crwdns2936753:030crwdne2936753:0 8
crwdns2942667:0crwdne2942667:0 183
