Hi! We need a bit more information to give you any real kind of answer as there could be so many reasons it’s not turning on for you at this point.
Did you drop it recently?
Any water or liquid exposure or damage?
How long has it been since you last had it turned on/charged and how long did you attempt to charge it for this time? Sometimes when a device’s battery is completely drained, it can take a bit longer for it to start showing anything on the screen.
Is the charger fitting properly into the device? If it feels loose or not going all the way in, your charging port may need cleaned.
It could also potentially be a motherboard issue: I’ve seen some iPhones come in for repair with a bad IC causing it to not want to charge or power on after dying, though I forget which IC that is.
Etc. Let me know.
crwdns2934113:0crwdne2934113:0
crwdns2915270:0crwdne2915270:0
crwdns2889612:0crwdne2889612:0
0
