Smart Auto Light Blinking
The Smart Auto Light is blinking. The dishwasher will start, go into drain mode, then start to add water when it suddenly stops, Smart Auto starts blinking and it goes thru several drain cycles. I have powered it off and turned it back on, I have turned OFF the circuit breaker for 5+ minutes, then switched it back on the circuit breaker and no luck. I have replaced the Brake Case. It still does not work. I am stumped and frustrated. A repair tech came out and did an electrical test and said the main board is fine and suggested the Brake Case replacement. What is wrong? HGow do I fix this? Please help!
Hi @johnwallac33198
A Smart Auto light only blinking error indicates a water supply problem with the dishwasher.
See p.40/58 of the service manual for what to check.
If you find the problem is a faulty part that needs replacing here's a link to the parts list that is useful.
Insert the full model number of your dishwasher (there are 7 models to choose from) and then select your model to find the list. When you locate the wanted part you'll see that the manufacturer's part number is listed for the part. Search online for that number to find suppliers that suit you best.
John Wallace crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 316
