How to connect the motor of the bike
Connecting a motor to your bike isn’t as hard as it might seem. First, you’ll need to mount the motor onto the bike frame, usually near the center or back wheel. Then, hook up the drive system, which could be a chain or a built-in motor hub, depending on what kind of motor you have. If it’s an electric motor, you’ll also connect the battery and controller using the wires that come with your kit (they’re usually color-coded to make things easier). Once everything’s attached, check that all the parts are tight and secure. Give it a quick test ride to make sure the motor runs smoothly and responds well. Take your time, follow the instructions, and you’ll get the hang of it.
crwdns2942667:0crwdne2942667:0 77
