Samsung family hub refrigerator error code 41
Woke up to refrigerator alarming saying error code 41 and to contact Samsung support center. In doing some research, I have found this to be happening to a large amount of people. I tried the reset process with red power button inside of top right door. I tried restoring to original settings and I even purchased and installed a new PCB. Upon power up of new PCB the refrigerator immediately alarmed error code 41. I checked wiring near top hinge of door as well. The settings for refrigerator and freezer temperatures can be changed but immediately revert back to previous settings. Cameras for inside refrigerator do not work, ice maker quit, continuously get alarms for temp inside refrigerator and freezer are too high. Can not access engineering mode either to force defrost for ice maker. Has anyone done anything else to correct this issue? I can't locate any articles that fix this issue besides the things I have already tried. Trying to stay away from Samsung support as the articles I read, the customers paid a tech to through parts at it. Please share your thoughts on any other resolutions I can try.
Hi @jamieb89984
What is the model number of the refrigerator?
Model number is RF22R7551SR/AA
Hi @jamieb89984
If you haven't already got it, it may be worthwhile to invest in the service manual and check if the troubleshooting guide provides any answers.
If you do find the problem and it is a faulty part that needs replacing, here's a parts list that is useful. Find the wanted part in the list to see the manufacturer's part number that is shown with it. Search online for the part number only, to find suppliers that suit you best.
Hi Jamie,
Did you get any resolution here? I have the exact same symptoms.
Given a comma error, I think it’s the connection from the door panel to the PCB.
On that basis my tech advised a new door assy?
Cheers.
Mark
Hi Mark and Jamie,
Did you guys ever get this resolved? I’m fighting the same problem and tried everything besides replacing the pcb. Wanted to see if others were successful before trying.
Thank you,
David
Jamie B crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 55
crwdns2942667:0crwdne2942667:0 740
