Complete repair manual for the PSP Go, including battery upgrade and display repair instructions.
The power Butten thing is stuck
the power Butten thing is stuck and i can not turn on because of the power Butten
@smellypoop let's see if the game console guru @dan0 can shed some light on this.
Hi!
So the power switch won't move anymore? If this is the case, open up the PSP go and check if there is anything inside, also clean it there.
If nothing is wrong so far and it is cleaned, then it need to be replaced. This repair will not be easy as you need to solder the new power switch in.
Part: https://kasynparts.com/product/on-off-po...
Guide: PSP Go Logic Board Replacement
In step 16 (2nd photo) you will find the power switch (left) soldered on the motherboard. Desolder it and solder the new one in again.
Please let us know how it goes, and good luck!
smelly poop crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 41
