171 x 77.6 x 9.5 mm Announced on 2019, July 22 Android 9.0 (Pie), ROG UI
Why is my phone not coming on?
After using my phone, I placed it down to do something. The battery was about 40% at that point. When i picked it up to use it again, it was not coming on.
I put it to charge for a while and the red light blinked for a few seconds and stopped. The phone did not come on.
I tried hard resetting but it still did not work. (Vol up, vol down, power button)
I saw a suggestion that said to hold the power button down while it charges but that just causes the red light to blink once every 15 seconds or so.
I sent it to a shop for diagnostics and was told that the battery and the digitizer was not the problem and the possibility is with the motherboard. The phone still does not come on.
Can you verify?
@mel8729 anything like that is hard for us to verify since we do not have direct access to the phone. I suggest that you get a USB-C ammeter and see how many amps your phone pulls from the charger when it is turned on. That way you have an idea if it does do anything. Next, I would consider replacing the charging port as well as the battery (if it is still the original battery) Then re-evaluate to see if your phone now charges and consumes power. Now you can work toward the motherboard since you now know that it is getting power.
Since iFixit does not have a specific guide for this, use something like this video to work on your phone. A replacement charging port is readily available at many online stores.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has a device with the same issues as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this. Repair is War on Entropy!
Mel crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 278
