Why does my RH controller keep losing connection?
Using my red RH controller it loses connection and re connects over and over. It doesn’t seem to be a battery issue but I haven’t ruled it out.
Hi Chrisa!
The right one does have an antenna connected to it's motherboard. Please open the Joy-Con and check if the antenna is still connected properly to the motherboard. This could cause the random disconnects.
Does the Joy-Con work perfectly fine while attached to the Switch?
Could also be the "Broadcom BCM20734 Bluetooth 4.1/2.4 GHz Transceiver IC"...
This required soldering plus soldering skills to get it fixed.
To test if it's the battery or not, you can also buy a grip holder with USB-C! While it's connected to the cable and still losing it's connection, it's definitely the blue-tooth messing around.
Good luck! And please let us know how it goes!
chrisa4357 crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 51
crwdns2942667:0crwdne2942667:0 149
