Screws stripped on iPhone 13 Pro
I can´t do the screen replacement on iPhone 13 Pro because both pentalobe screws are stripped. Tried with glue without success. What to do?
Evening,
I'm honestly not sure if there's another way to get them about apart from drilling them with a tiny drill bit. Either way you have to get new screws so that might be your only option.
@np_f1_2021 Thank you. Which drill should I buy, could you if possible send a link? And how should I drill them out? I guess from the outside?
@imados i don't know whereabouts you live (countrywise), but even then i cant find a 0.8mm drill bit in australia so it might be best to get something like a 1mm drill bit. BUT keep in mind you could accidentally drill a hole in the phone so be extremely careful if you do decide to drill it out.
@np_f1_2021 Appreciate your great help. I honestly dont know what to do, but I think the best way maybe is to drill the screws out.
Before buying anything use a rubber band over the tip of screwdriver and magnet to help pull it out let me know if you have questions
