Model A2159, EMC 3301. A refresh of the entry-level 13" MacBook Pro. Available in Silver and Space Gray. Released July 2019.
No display, Fans spins & trackpad clicks
Hello everyone,
I've finally come upon another MacBook that has shown no mercy to being fixed so here I am once more. Fortunately it showing minimal signs of life (Kind of like its on life support) but no display no chime nothing visual or audial aside from the fans spinning and the trackpad vibrating. Any advise would be greatly appreciated. TIA!
If the fans are spinning and the trackpad is responding but there are no other signs of life, then you'll need to do some troubleshooting to figure out what's going on. Some things you can do to get more information:
• Test using charger and internal battery disconnected
• Test with external monitor with internal display disconnected
• With the battery disconnected, use an ammeter in-line with the charger to read the amperage and voltage that the system is drawing
• Test power on with other internal components disconnected (trackpad, top case, TouchBar, etc.)
This kind of testing can help you figure out which component is causing the problem. If the issues persist even when you have most components disconnected from the logic board then in most cases you can assume the issue is due to a fault on the logic board.
Good luck!
Awesome Zach, thank you. I will go ahead and try this and let you know of my findings!
@compjinxmagic - To add to Zach’s answer I find a USB-C power meter makes quick work in testing as you can also see how the power logic is responding. The voltage will cycle if things are working internally.
Corey Meyer crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 8
crwdns2942667:0crwdne2942667:0 70
