The Maytag Washer model MVWB765FW is a top-load washing machine with a deep fill option. The washer has a volume of 4.7 cubic feet.
Machine draining but not all the way
Maytag top load washer. No error codes, no strange noises, etc. water drains but the clothes are still too wet for the dryer. Run a drain and spin and that does the trick. No hose blockages, took the pump off and no blockage at the pump.
Does a partial drain indicate the pump needs to be replaced?
Hi @buckgerard
What is the complete model number of your washer?
There are 5 different variants of the model i.e. MVWB765FW0 - MVWB765FW4 and they are not all wired exactly the same or use the exact same parts.
The model # is MVW6200KW2. Thanks
Hi @buckgerard
Here's the tech sheet for the washer that may help.
Run the diagnostics as described by the sheet and check if you get an F9 E1 error code.
Here's the tech sheet for some the other models which may help further as it more comprehensive and describes how to check if the drain pump is OK - see Test#7 on p.19.
Here's the parts list for your model. If there's a faulty part, locate the wanted part in the list and it'll show the manufacturer's part number. Search online for the part number to find suppliers that suit you best.
crwdns2944067:09crwdne2944067:0:
Looks like its F7 E7
then I ran the test again and got no error message. (all leds blinked 2x then went dark)????
@buckgerard
If the machine is still working, see the 2nd tech sheet linked above for what to check for an F7 E7 error code.
I replaced the control board. The control board light is blinking indicating no issues. When I enter diagnostic mode the UI test works fine. But when I try to run the self test nothing happens. The 4 lights blink three times then nothing. When I exit diagnostics and power on, the sense light is blinking. I try to run a cycle and nothing happens. Any ideas?
@buckgerard
Can you hear the door lock clicking shut when starting the machine?
A sensing light on a Maytag usually indicates a problem with the lock mechanism.
Just verifying that when entering diagnostic mode, after pressing the keys 1-2-3 x 3 that you then press key 2 and then key 5?
crwdns2934275:04crwdne2934275:0
buckgerard crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 4
crwdns2942667:0crwdne2942667:0 92
