Complete repair manual for the PSP Go, including battery upgrade and display repair instructions.
Why my PSP Go does not play sound through the speakers?
I bought a used pcp go and I found that it does not play sound through the speakers, but when I connected through the jack headphones the sound works. What should I do?
Hi!
Could be the actual speaker, the headphone jack OR a fuse.
Here is the fuse replaced: Loss of audio Output From Units speakers..
You need to open the console and do a continuity test for the fuse. If the fuse is okay, then replace the speaker and the headphone jack. Both are like $1 or $2.
Guide for removing the motherboard: PSP Go Logic Board Replacement
Please let us know how it goes!
How do I check to see if the fuse is working?
Hi! You can do continuity test with a multimeter. As long as it “beeps” when holding the pins to each other ends, it’s fine. If it does not beep, then it need to be replaced! Good luck!
@dan0 My multimeter is not beeping and when I short the pins on the fuse, the multimeter in ohmmeter mode shows nothing, but on the other fuse it shows a number. does this mean I need to unsolder the fuse? if so, how do I make a bridge?
If the multimeter is not showing anything on the fuse, then the fuse is broken and need to be replaced. Best thing is to solder a new fuse on it with the same values.
@dan0 When I replaced the fuse, I first time I plugged the cable backwards then fine, sound works but no backlight, is it because I plugged the cable in the wrong direction?
The Dad crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 363
