no feed to amplifier
Amplifier works on cd but not turntable (analogue input)
Your turntable will likely need a preamp as the signal is too weak. Some amps have this built in but yours probably doesn't.
Check your amplifier's manual. It should tell you.
Do you connect the output from turntable into the PHONO connection on the amplifier?
Because the turbtable only send the low and weak signal (maybe 2.2mV for MM or even lower as around 0.4 mv For MC head), so if you connect to CD or AUX port on the back of amplifier, you won't hear enough sound.
If you don't have PHONO input, then you should find a PHONO amplifing machine in between the two machines, which can be found in fairly low price about under 100 bucks for low grade types.
If you already used the phono port, then you should check if the turntable get some issues to send the signal.
crwdns2936753:030crwdne2936753:0 3
crwdns2942667:0crwdne2942667:0 51
@brianhall83790 what amplifier? Make and Model? what have you checked?
crwdns2934271:0crwdnd2934271:0 oldturkey03 crwdne2934271:0
