Released April 30, 2021 and identified by model number AN515-55.
My Laptop doesn’t even turn on when connected to power
Okay, so I noticed the model of nitro 5 I had did not have a page dedicated to it, so I decided to make one.
Onto my laptop. I was using it normally and all of sudden everything just went black. I didn’t shake it or anything, although it’s worth mentioned that it has blue screened a ton in the past thanks to dropping it a few times.
After it goes black I quickly check whether the charging light is on, it isn’t. It seems like it’s fully bricked. I tried turning it on a ton no response and no lights for that matter. I thought it was a socket issue, changed it and still no avail. I removed the charger and tried starting it, there was no use. I tried almost everything that was there in the online help guides nothing worked. It definitely should be a hardware issue.
I even tried waiting for several hours with the laptop unplugged from the charger, still no light or anything for that matter. Looks like it’s been fully bricked. I can’t identify the issue either. Does any parts have to be replaced?
Did you find out what happened
@j0hn25972 Start off with the easy things. Disconnect the power from the computer by unplugging the power cord from your computer. Disconnect all external devices from the computer. Now hold the power button depressed for about 30sec-1min. Reapply the AC power adapter and see if your computer does show any sign of life.
Of course, it is also possible that this is a bad RAM module or a bad LCD. So remove the RAM, clean the contacts with a pencil eraser. Do it gentle so as to not destroy the module. Replace it and restart. If you have more than one module, remove it and just leave one connected. after that, try the other one.
Hey so I took it to a repair shop and found out what was wrong, turns out few components blew out leading to the whole laptop just refusing to turn on
For some reason it doesn't let me create another page to ask another question but I have a similar issue. Everything was working fine until I got a message when I tried to download a game saying to update the intel driver, I went online and clicked it and install the application that scans it and tells me what I need to install in the intel page and then after installing it and rebooting it when I triedd playing warzone on my laptop it crashes and refuses to turn on. Do note that before this warzone was running fine. Now the laptop turns on for 1 second the backlights turn on and then it goes off, repeated all steps including holding the power button etc. I cant remove the battery as its attached but there is no use since the battery has been dead for a while. I somehow go it working again and I tried reinstalling the old intel driver and it crashed again, now its refusing to turn on regardless of what I tried.
Since it has no sign of Life, check the charger adapter is working or not, if charger is Okay then check the Power or Charger LED indication does it indicates any light condition like blinking or Blink one time & goes off.this type of indication lead to Shorting on the Motherboard, if you are not pro-technical, i advice you to take it to the proper service technician , do not try "DIY" if fault is on component level or situation or chances for repair is worst.
Hey so I took it to the shop and they said that there was water damage on the laptop leading to some components being blown out, there is no issue now ty
J0hn crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 47
crwdns2942667:0crwdne2942667:0 827
