Huawei Y7 2018 smartphone runs on Android v8.0 (Oreo) operating system. The phone is powered by Octa core, 1.8 GHz, Cortex A53 processor. It runs on the Qualcomm Snapdragon 450 Chipset. It has 2 GB RAM and 16 GB internal storage.
Why my phone consume the battery so faster
Common Causes and Solutions:
  1. Background Apps:
    • Cause: Apps running in the background can consume a lot of power.
    • Solution: Close unused apps. Go to your settings and check for apps running in the background. On most phones, you can find this in the "Battery" section.
  2. Screen Brightness:
    • Cause: High screen brightness uses a lot of battery.
    • Solution: Lower your screen brightness or set it to auto-adjust. You can usually find this in the "Display" settings.
  3. Location Services:
    • Cause: GPS and location services are power-hungry.
    • Solution: Turn off location services when not needed. Go to "Location" in settings and switch it off, or use it only when necessary.
  4. Push Notifications:
    • Cause: Constant notifications from apps can drain the battery.
    • Solution: Limit push notifications. Go to "Notifications" in settings and customize which apps can send you alerts.
  5. Old Battery:
    • Cause: Batteries degrade over time.
    • Solution: If your phone is old, consider replacing the battery. Check with a professional or the phone’s manufacturer.
  6. Apps Using Too Much Power:
    • Cause: Some apps are poorly optimized.
    • Solution: Check battery usage in settings to see which apps use the most power. Consider uninstalling or updating these apps.
  7. System Updates:
    • Cause: Outdated software can have bugs that cause battery drain.
    • Solution: Ensure your phone’s software is up-to-date. Check for updates in "System" or "Software Update" settings.
  8. Widgets and Live Wallpapers:
    • Cause: These can constantly use resources.
    • Solution: Use static wallpapers and remove unnecessary widgets.
  9. Wi-Fi, Bluetooth, and Mobile Data:
    • Cause: Keeping these on all the time can drain battery.
    • Solution: Turn off Wi-Fi, Bluetooth, and mobile data when not in use. Use airplane mode in areas with poor reception.
  10. Battery-Saving Mode:
    • Solution: Enable battery-saving mode. This reduces performance and limits background activity, helping to extend battery life.
Happy Darren crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 248
